width50%
The Stucco texture is a procedural texture that produces a surface effect similar to an uneven, almost dented stucco surface. Both of its color channels can be connected to texture maps if required.
UI Path: ||V-Ray Node Editor|| > Shader > Add > Textures V-Ray Stucco
width5%
width45%
width50%
Image Added
width50%
 Image Removed
Node Input Sockets
width50%
This section describes the input sockets of the node. Some sockets have dedicated parameters, which are further described below, and some sockets are just inputs.
Mapping – Allows a UVW Mapping or a UVW Randomizer node to be connected to determine the mapping of the ramp.
Color1 (input socket) –  Allows a color node to control the
Uvwgen  Allows a UWV modifier to be attached to determine the UVW placement of the texture.
Color1 – Controls the main stucco color.
Color2 – Controls the stucco (input socket) – Allows a color node to control the dot color.
width5%
width45%
Image Added
Properties
width50%
Color1 – Controls the stucco color when no node is connected.
Color2 – Controls the dot color when no node is connected.
Size – Controls the scale of the produced texture.
Thickness – Controls how thick the Stucco effect appears.
ThresholdControls which areas contain the texture's features.
width5%
width45%
Image Added
