name to be confirmed - maybe configuration? To run V-Ray, you have to:
Progress Bar Container
step32
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
urlInstallation
titleStep 2: Activate your Product
urlActivate your Product
After installing V-Ray for Blender, load the Add-on in Blender and sign in with your Chaos account when prompted.
Steps
width50%
When you open Blender, go to Edit > Preferences. This opens the Blender Preferences window. Go to the Add-ons tab, and search for V-Ray. Make sure to turn off the Enabled Only option.
Enable the V-Ray For Blender plugin.
Continue according to your license setup:
Solo and Cloud-Based Floating Licenses
Network Floating Licenses
width5%
width45%
Image Added
Anchor
solo
solo
If you have a Chaos Solo license plan or are connected to a Cloud-Based Floating License, follow these steps:
width50%
Using V-Ray requires an account with an active license. V-Ray for Blender will prompt you to sign in, if needed. Select Sign in from this dialog and enter your Chaos account credentials on the Chaos accounts Sign in webpage.
Panel
borderColor#cce8ca
borderStylesolid
Read more about the licensing process and functionality in the Chaos Licensing documentation.
width5%
width45%
Image Added
width50%
Then, from the Render Properties, select V-Ray as the Render Engine.
width5%
width45%
Image Added
Anchor
net
net
If you are connecting to a Floating Chaos License, which is set up to be shared within a network, follow these steps.
width50%
Fancy Bullets
typecircle
  • The administrator needs to give you their machine's IP address. This serves as your connection point to the Chaos License.
  • When installing your Chaos product, at the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port. See the Installation page and follow the steps for your Chaos installation.
  • You are automatically connected to the active licenses after completing the installation.
Panel
borderColor#cce8ca
borderStylesolid
width5%
width45%
Image Added
Example screenshot
width25%
Load V-Ray in Blender
width50%
width5%
width45%
Image Added
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Blender
url
