HideElements
cssselector#tocVertical, #tocHorizontal
This page provides information about the Help menu and its sub-menus in Chaos Vantage.
Menu options
width60%
Documentation Homepage – Opens the Chaos Vantage online documentation.
"Getting Started" Tutorials – Opens the Getting Started page of the Chaos Vantage online documentation.
Support Forums – Opens the support forum page in an internet browser.
Open Debug Log – Opens the Debug Log window. Please check the Debug log Log section below for more infoinformation.
Check for Updates – Forces a check if you are running the latest version of Chaos Vantage.
AboutShows you information about the installed versionOpens the About Chaos Vantage window. Please check the About Chaos Vantage Window section below for more information.
width5%
width35%
Anchor
debugLog
debugLog
Debug Log
width60%
Filters the log window to show lines that have the input string.
Clears the input field in the Filter box, resetting the shown log window info.
Filters the type of messages to show in the log window.
Lines do not wrap at the right end of the log window.
Lines wrap at the right end of the log window.
Specifies the font size in the log window.
Detaches the log window from the app so that it remains open even if Chaos Vantage is minimized.
Clears the log window.
Opens the log location folder.
width5%
width35%
width60%
The About Chaos Vantage window provides information about the installed Vantage version, that can be copied. It also provides links to the following:
Fancy Bullets
typecircle
The window is accessible from Vantage's Help menu > About.
width5%
width35%
Image Added
