This page provides information about the Help menu and its sub-menus in Chaos Vantage.
Menu options
width | 60% |
width | 5% |
Anchor | ||||
width | 35% |
Filters the log window to show lines that have the input string. | |
Clears the input field in the Filter box, resetting the shown log window info. | |
Filters the type of messages to show in the log window. | |
Lines do not wrap at the right end of the log window. Lines wrap at the right end of the log window. | |
Specifies the font size in the log window. | |
Detaches the log window from the app so that it remains open even if Chaos Vantage is minimized. | |
Clears the log window. | |
Opens the log location folder. |
width | 5% |
About Chaos Vantage Window
The About Chaos Vantage window provides information about the installed Vantage version, that can be copied. It also provides links to the following:
type | circle |
width | 35% |
The window is accessible from Vantage's Help menu > About.
width | 5% |
My Account Window
width | 60% |
The My account window, accessible from Help > Chaos account in Vantage,
This window displays details of the account you're currently logged into and includes a direct link to your online account management page, where you can view active products and update your account information and preferences. You can also easily switch between accounts or sign out entirely.
A link to the Chaos License Server is also available. From there, you can manage licenses for your installed Chaos products and view the status of your licenses.
shows you which account is used currently as a license holder.
Press the Manage account button to open My Chaos portal and manage the licenses. You can assign, remove, allocate licenses to different users. For more information, see the My Chaos Portal Guide page.
To switch the current account, press the Sing out button.
If you haven't signed in during the installation, you can do so in this window:
See Chaos plans & pricing link leads you to Vantage's pricing list on Chaos website.
This window blocks all the rest of the UI, so make sure to close it once done to go back to Vantage.
width | 5% |
Column | ||
