width50%
The Shadows Render Channel works as a reverse mask for shadows. It is a color image that can be used to lighten, darken, or tint shadows. Shadows can be lightened in the composite by adding this render channel or darkened by subtracting this render pass from the final composite.
The Shadow render channel is the product of multiplying the Raw Shadow Render Channel with the Diffuse Render Channel in the composite.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Shadow
width5%
80%Image Added
width45%
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAftershadow channel
height
Properties
width50%
Enable Deep Output Specifies whether to include this render channel in deep images.
Color Mapping
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
width5%
width45%
Image RemovedImage Added
