Comment: Reverted from v. 13
The GI render element has no controllable properties.
Common Uses
The Global Illumination Render Element is useful for changing the appearance of Indirect lighting after rendering, using a compositing or image editing software. Below are a couple of examples of its use.
width10%
width40%
Image Added
width40%
Image Added
Original Beauty Composite
width10%
width10%
width40%
Image Added
Brightened Global Illumination Render Element
width40%
Image Added
Brightened GI
width10%
width10%
width40%
Image Added
Brightened and tinted Global Illumination Render Element
width40%
Image Added
Tinted and tinted Brightened GI
width10%
Compositing Formula
GI Raw x Diffuse = GI
