This page provides details on the V-Ray for Revit UI and how it is integrated into the Revit interface.
The VThe V-Ray for Revit Ribbon gives you access to all of the settings and options that you will need with V-Ray.
width20%
width60%
width20%
View
This allows you to select which one of the Revit 3D views to render.
Gives you access to the options for the V-Ray Sun, V-Ray Dome Light, No V-Ray Lights, and Artificial Lights.
Assets
Gives you access to the V-Ray Asset Editor and V-Ray Appearance MangerManager, and Chaos Cosmos Browser.
Image Modified
Camera
Gives you access to the V-Ray Camera settings.
Fancy Bullets
typecircle
  • Online Help - This will take to you the V-Ray for Revit home page.
  • Disable V-Ray - Releases your V-Ray license. V-Ray for Revit will be locked and won't be available for use.
  • About - Displays V-Ray version information, Credits and Copyrights, and the End User License Agreement, as shown in the image below.
  • Feedback - redirects Redirects to the V-Ray for Revit forum where users can give us feedback.
  • License Server - Opens a webpage to your Online License server information.
width45%
Image Modified
width55%
