The utilities can be used to quickly control the safe area and background of the Preview Area and also give access to some caching options and other utilities.
IconDescriptionContext options
Shows and hides the Safe area and Mask in the Preview Area. Right click to choose from the following set of predefined settings for the Mask and Safe area
Toggles between black and checkerboard background. Right-click to open more options.
In addition to the default colors, you can choose a custom color or paste a color that you copied. You can also set any color as a Default color.
Toggles automatic preload
Preloads all layers. This option is available when Disable caching globally is not used.
Disables caching globally.
Toggles the cache resolution between Full ResolutionHalf Resolution, and Quarter Resolution. This is useful to speed up the working process when you are short of RAM.
Shows the metadata viewer.
Toggles the HTTP Server on and off. Right clicking allows you to Copy the server address or Open the server in a browser.
Shows and hides the Property Panel.
