You can bring up the preview area context menu by right-clicking anywhere in the Preview Area. It has some commands that are already available as buttons as well as some new commands and shortcut keys to them.
Reset/Fit to window – Toggles the zoom factor between 100 percent and one that would fit to the window size.
Full Screen Mode – Toggles between normal and full screen mode where you have larger preview area and the Menu Area is hidden.
Layer Properties – Shows and hides the Layer Property Panel.
Pixel Info – When enabled, the toolbar displays information about the pixel that the mouse is currently hovering over. This includes X and Y coordinates, RGB and HSV color values.
Mask Safe Area – Shows and hides the Mask and Safe Area.
Grid – Shows and hides the grid.
Synchronize Display – Toggles vertical synchronization on and off.
Resize Window to Fit – Resizes the window to fit the current zoom factor. This will only work if the window is not maximized.E-mail Screen as JPEG – E-mails a screenshot of the window in .jpg format using the system’s default e-mail client.
E-mail Screen as PNG – E-mails a screenshot of the window in .png format using the system’s default e-mail client.
Copy Mask Copy Composition as Image– Takes whatever is visible in the Safe Area and Mask and puts it in the clipboard.
Copy Screen as Image – Takes the current screen and puts it in the clipboard.
Paste – Pastes the clipboard content as new layer. If the clipboard contains previously copied frame or layer from Chaos Player it will be pasted as a new still image layer or sequence layer respectively. You can copy one or more images from Windows Explorer to the clipboard and paste them as clipboard layers. In cases where single or multiple directories are copied, Chaos Player will paste them as sequence layers.
Paste as Single Frame – Pastes the content of the clipboard as a Single Frame Layer.
Paste as Embedded Image – Pastes the content of the clipboard as a new Embedded Image Layer.
Copy Color – Copies the RGB values of the color under the cursor.
