This page provides information on the Preview Area of the Chaos Player User Interface.
The Preview Area is where most of the work with Chaos Player takes place.
User Interface
Preview Area
The Workspace is where the layers are shown. Here they can be moved in respect to each other and the Workspace center. You can also scale them and see the results from other modifications you apply on them.
The Mask makes it easy for us to see what parts of the layers will be visible in the final out put. The Safe area is a part of the mask that takes into consideration the fact that monitors and TV sets clip out the corners of the incoming video signal. The Safe area actually shows the user which parts of the final output will be clipped out and which will be shown when it is displayed by a regular TV Set. You can pan and scan the work space in respect to the mask and safe area by dragging with the middle mouse button. To reset the zoom and position of the workspace press the Num Pad 5 button once. Pressing it again will toggle the zoom factor between 100% and the one that will fit the current workspace to the window size.
Layers in work space
The image below shows two layers in the Workspace. The top one is selected and we can see the Scale handles in the corners. You can click on each handle and drag to scale the layer. Chaos Player also allows you to crop the layer by pressing Shift + K. This will bring out the crop area which is represented by a dotted line rectangle. You can scale and move the crop area just like you would do with a layer while holding down the Shift Key. When you have finished positioning and release the Shift Key you will be able to see only the part of the layer that lies within the crop area.
Crop Layer
Context Menu
You can bring up the preview area context menu by right-clicking anywhere in the Preview Area. It has some commands that are already available as buttons as well as some new commands and shortcut keys to them.
Reset/Fit to window – Toggles the zoom factor between 100 percent and one that would fit to the window size.
Full Screen Mode – Toggles between normal and full screen mode where you have larger preview area and the Menu Area is hidden.
Timeline – Shows and hides the Timeline Area.
Layer Stack – Shows and hides the Layer Stack.
Information Bar – Shows and hides the Information Bar.
Layer Properties – Shows and hides the Layer Property Panel.
Pixel Info – When enabled, the toolbar displays information about the pixel that the mouse is currently hovering over. This includes X and Y coordinates, RGB and HSV color values.
Safe Area – Shows and hides the Mask and Safe Area.
Grid – Shows and hides the grid.
Synchronize Display – Toggles vertical synchronization on and off.
Resize Window to Fit – Resizes the window to fit the current zoom factor. This will only work if the window is not maximized.
Copy Composition as Image – Takes whatever is visible in the Safe Area and Mask and puts it in the clipboard.
Copy Screen as Image – Takes the current screen and puts it in the clipboard.
Paste – Pastes the clipboard content as new layer. If the clipboard contains previously copied frame or layer from Chaos Player it will be pasted as a new still image layer or sequence layer respectively. You can copy one or more images from Windows Explorer to the clipboard and paste them as clipboard layers. In cases where single or multiple directories are copied, Chaos Player will paste them as sequence layers.
Paste as Single Frame – Pastes the content of the clipboard as a Single Frame Layer.
Paste as Embedded Image – Pastes the content of the clipboard as a new Embedded Image Layer.
Copy Color – Copies the RGB values of the color under the cursor.
