Common Uses
The Raw Lighting Render Element is useful for changing the appearance of direct lighting after rendering in a compositing or image editing software. Below are a couple of examples of its use. In this set of render elements, direct lighting affects the floor and wall a great deal more than the ceiling.
Underlying Compositing Equation
example, you can see how the image looks before and after post-production.
Before after | ||||||||||
VRayRawLighting VRayRawLighting x VrayDiffuseFilter = VRayLighting
