width50%
The V-Ray HairFarm Modifier can be used to render hair strands produced by the Hair Farm plugin by CyberRadiance. This allows the hair to blend seamlessly into the V-Ray rendering pipeline and to properly interact with features like 3D motion blur, V-Ray lights, global illumination, etc.
Please note that VRayHairFarmMod requires Hair Farm 2.0 and later.
UI Text Box
typeinfo
It is strongly recommended to use hair materials for hair-based objects used for simulating hairs.
UI Expand
expandedtrue
titleUI Path: ||Select geometry|| > V-Ray menu > Create > Modifiers > V-Ray HairFarm Mod
||Select geometry|| > Modifiers menu > V-Ray VRayHairFarmMod
||Select geometry|| > Command panel > Modify tab > Modifier list > VRayHairFarmMod
width5%
width45%
