VRayVFB – – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies – Applies the color mapping options specified in theColor mapping rollout rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies – Specifies whether to denoise this render element.
