width60%
The V-Ray Toon Render Element renders the entire scene with the V-Ray Toon Render Effect and contains a mask for the toon outlines, although the toon color is not present in it. It also supports opacity set from the toon effect, presenting it as grayed outlines.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayToon
Image Added
Image Removed
width5%
width35%
Image RemovedImage Added
width60%
VRayVFB  – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Invert color – Inverts the black and white colors.
UI Text Box
typenote
For the toon effect to be visible in the V-Ray Toon Render Element, the VRayToon Render Effect must be present and active.
width5%
width35%
Common Uses
The V-Ray Toon Render Element is is useful for changing the appearance of a render in a compositing or image editing application.   The VRayToon Render Element holds a mask for the toon outlines (the toon color is not present in it).
It has an option to invert its output, so instead of white lines on a black background, we can get the opposite. It also supports opacity set from the toon effect. See how V-Ray Toon looks with inverted colors.
width10%30%
Image Removed
V-Ray Toon Render Element with invert color enabled
width40%
Image Removed
width40%
width10%
Before after
afterLabelInverted
beforeLabelOriginal
Panel
borderStylenone
Image Added
Panel
Image Added
column
width5%30%
width30%
When V-Ray
materials reflections and refractions are not set to Affect All channels
width30%
, V-Ray Toon
width30%
Image Removed
V-Ray Toon Render Element composited over the VRayDiffuseFilter render element while set to multiply in composite
width5%
is not applied to them. See how the RE looks when that mode is set and when it is not. In this example, Invert color is enabled.
Before after
afterLabelEnabled
darktrue
beforeLabelDisabled
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
V-Ray Toon is often used for creating cartoon-like renders. This can be achieved my Multiplying it by the V-Ray Diffuse Filter Render Element in a compositing or editing software.
Image Added
Fancy Bullets
typecircle
  • For the toon effect to be visible in the V-Ray Toon Render Element, the VRayToon Render Effect must be present and active.
  • When the Do reflections/refractions option is enabled for the V-Ray Toon Effect, then in order for all reflected and refracted toon lines to be present in the render element, you need to set the V-Ray materials' reflection and refraction to Affect All channels. Lights must also be turned on within the scene or no reflections/refractions will be present in the render.
