This page provides details on the V-Ray Toon Render Element.
The V-Ray Toon Render Element renders the entire scene with the V-Ray Toon Render Effect and contains a mask for the toon outlines, although the toon color is not present in it. It also supports opacity set from the toon effect, presenting it as grayed outlines.
VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Invert color – Inverts the black and white colors.
For the toon effect to be visible in the V-Ray Toon Render Element, the VRayToon Render Effect must be present and active.
Common Uses
The V-Ray Toon Render Element is useful for changing the appearance of a render in a compositing or image editing application. The VRayToon Render Element holds a mask for the toon outlines (the toon color is not present in it).
It has an option to invert its output so instead of white lines on a black background, we can get the opposite. It also supports opacity set from the toon effect.
V-Ray Toon Render Element with invert color enabled
V-Ray Toon Render Element with Do reflections/refractions enabled in the VRayToon Render Effect and invert color enabled
(all V-Ray materials reflection and refraction have not been set to Affect All channels)
(all V-Ray materials reflection and refraction have been set to Affect All channels)
V-Ray Toon Render Element composited over the VRayDiffuseFilter render element while set to multiply in composite
- For the toon effect to be visible in the V-Ray Toon Render Element, the VRayToon Render Effect must be present and active.
- When the Do reflections/refractions option is enabled for the V-Ray Toon Effect, then in order for all reflected and refracted toon lines to be present in the render element, you need to set the V-Ray materials' reflection and refraction to Affect All channels. Lights must also be turned on within the scene or no reflections/refractions will be present in the render.
