Floatingpagetoc
CSS Stylesheet |
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size { vertical-align: text-bottom; } |
This page provides information about Chaos Vantage's Animation Editor.
UI
The Animation editor can be accessed by clicking on the Animation Editor button(
) in the bottom toolbar:Section | |||||||||||||||
Button | Description | ||||||||||
Expands the Animation Editor. | |||||||||||
Sets the playback speed. | |||||||||||
When enabled, loops the animation. | |||||||||||
Plays the animation. (Shortcut: Space) | |||||||||||
Sets start of animation sequence | |||||||||||
Sets end of animation sequence | |||||||||||
When enabled, automatically updates image sequences and animated meshes for the current frame of the timeline or when scrubbing the timeline. Does not update when playing the animation from the Play button. Not available in Live Link. (Shortcut: U) | |||||||||||
Opens Render setup dialog.
Saves a high quality snapshot of the current view in the project folder from where the scene file has been imported. |
UI Text Box | ||
You can crop your animation sequence using the Set Start and Set End markers |
Animation Editor Parameters
Left Side Parameters
Right Side Parameters
Timeline
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||
Animation Editor Modes
Time Mode
Time mode of the animation editor enables the following workflow:
Fancy Bullets | ||
Shot Mode
Shot Shot mode of the animation editor enables the following workflow:
Fancy Bullets | ||
Context Menus
Additional parameters of the clips can be accessed by right-clicking on an item to display a context menu. In the camera animation track, you can have the following items with context menu options:
Right-click on camera clip
Right-click on Scene animation
Right-click on transition item
Right-click on pause item
Right-click on blue transition/camera marker
