This page provides information about the Materials tab in Chaos Vantage.
Responsivegridmacro
HAlignmentcenter
Columns2repeat(4, 1fr)
Columns3width1000px
Columns1repeat(6, 1fr)
Columns3repeat(3, 1fr)
Gap5px
Columnsrepeat(6, 1fr)
ClassRespColumns3
Floatingpagetoc
CSS Stylesheet
.sectionMacro .columnMacro + .columnMacro {
padding-left: 0;
width65%
The materials tab offers a list of all materials in the scene. This includes materials imported with .vrscene file.
Material override
Clay mode – When enabled, overrides all scene materials with a simple grey(default) material.
Clay color –Specifies the color for the override material.
Use reflection – When enabled, the original material's reflection setup will be used instead of overriding it.
Use refraction – When enabled, the original material's refraction setup will be used instead of overriding it.
Use bump – When enabled, the original material's bump setup will be used instead of overriding it.
Use opacity – When enabled, the original material's opacity setup will be used instead of overriding it.
Use self illumination – When enabled, the original material's self illumination setup will be used instead of overriding it.
ButtonDescription
Assigns a material from the list to the selected objects in the scene. Available only when a material is selected.
Selects all scene objects based on the material that has been selected in the list. Available only when a material is selected.
Selects the material of the selected object in the scene. Available only when an object is selected.
Opens the Preview scene settings dialog.
Filters the material list and shows only the ones that contain the input string
Clears the filter string.
Filter menu that enables the listing of materials based on type e.g. Generic, 2 Sided, Multi material, etc.
Controls the amount of columns in the materials list:
Sorts the material list:
width5%
width30%
width65%
There is also a context menu with a right click on a material thumbnail:
Select objects by material – Selects all scene objects based on the material that has been selected in the list. ()
Assign material to selection – Assigns a material from the list to the selected objects in the scene.()
Assign material to selection and its children – Assigns a material from the list to the selected objects and their children in the hierarchy in the scene.
Delete unused Cosmos material assets – Deletes any currently unused imported Cosmos material assets. This will free up GPU memory.
width5%
width30%
UI Text Box
typeinfo
Materials can also be assigned to objects by drag-and-drop. There are also modifier key combinations with drag-and-drop with the following functionality:
Fancy Bullets
typecircle
  • Alt+drag-and-drop replaces material on all object with same material
  • Ctrl+drag-and-drop assigns material to objects and its children
Preview Scene Settings
width65%
The Preview scene settings dialog contain options to customize how the material thumbnails are rendered.
Load vrscene – Loads a custom vrscene file for the material preview scene.
Expand
titleClick here to expand additional details about the material preview scene...
The material preview scene has the following requirements in order to be loaded properly:
Fancy Bullets
typecircle
  • scene must contain at least 1 object with '__thumbnail_target' user attribute
  • scene objects(nodes) that will be listed in the Preview mesh drop-down must have a '__thumbnail_target' user attribute set. Different objects must have incremental values e.g __thumbnail_target=1, __thumbnail_target=2
Features of the loaded material preview scene :
Fancy Bullets
typecircle
  • scene lights will be listed and their color, intensity and enable/disable properties can be modified
  • scene cameras will be listed in the Preview camera drop-down list
  • objects that have a '__thumbnail_target' user attribute set will be listed in the Preview mesh drop-down
UI Text Box
typeinfo
width65%
 Sample preview scene with a background, 2 cameras, studio light setup, a sphere and a teapot can be downloaded using the download button.
width5%
width30%
UI Button
colorblue
icondownload
titleDownload
urlhttps://drive.google.com/uc?id=13XHYDIfK4MSuH9PnQmClkrvm0gr5qFNk
UI Text Box
typewarning
Please note that the loaded scene will replace the current preview scene. If there are no lights and/or an environment texture or color set then the preview thumbnail will render black.
Samples – Specifies the samples per pixel for refining the material thumbnail. Low values will speed up thumbnail generation at the cost of quality.
Preview mesh – Specifies the mesh that will be used in the material thumbnail:
div
stylepadding:5px; row-gap: 0px;
classRespColumns3
Sphere
Cube
Cylinder
Shaderballl
Liquid
Cloth
Preview camera – Specifies the render camera for the material thumbnails:
div
classRespColumns3
Main
Zoom
Environment mode – Specifies the mode which will be used for scene lighting.
Texture – Enables the use of an environment texture for lighting. When this option is selected, Load environment and Rotation parameters appear.
Solid Color – Enables the use of a solid color for lighting. When this option is selected, Environment Color parameter appears.
Load environment – Loads an image for Environment. This option is available only when Environment mode is set to Texture.
Flip horizontally – Flips the environment image horizontally. This option is available only when Environment mode is set to Texture.
Rotation – Specifies a rotation angle in degrees for the Environment texture. This option is available only when Environment mode is set to Texture.
Intensity – Specifies the intensity of the Environment lighting.
Rim Light – Enables/disables and controls the intensity and color of the rim light in the default preview scene.
Fill Light – Enables/disables and controls the intensity and color of the fill light in the default preview scene.
Front Light – Enables/disables and controls the intensity and color of the front light in the default preview scene.
Internal Lights – Enables/disables and controls the intensity and color of the internal light in the default preview scene. Useful for previewing two sided  materials.
Close – Closes the Preview scene settings dialog.
width5%
width30%
