Commands can be passed directly from the command line or from a text file.
System
Command | Description |
--attach | Attach to an already running Chaos Player instance and pass it the rest of the command line. |
--cmdfile=filename.txt | Execute the commands from filename.txt. |
--transient, --transient={0,1} | Start Chaos Player in transient mode, so that settings are not saved on exit. |
--back_color=black (dark_grey, green, blue, magenta, white, transparent) | Set background color |
--safe_area=none (green, orange) | Set safe area type |
--mask_type=none (transparent, crop, crop_safe) | Set mask type |
--mask_size=720,576 | Set mask size |
--grid=0 (1) | Turn grid on or off |
--counter=frame (timecode) | Set counter type |
--repeat_type=none (ping_pong, loop) | Set repeat type |
--fps=29.97 | Set fps |
--timeline=140 | Set the timeline length in frames |
--wa_begin=10 | Set work area start frame |
--wa_end=120 | Set work area end frame |
--time=7 | Set current time |
--zoom=250 | Set zoom (in percents) |
--pan=0,0 | Set pan position |
--frame_base=0 (1) | Set frame base (whether frames start from 0 or from 1) |
--ext_device= {decklink,firewire,vtoaster,bluefish} | Set external output type |
--selected_layer=4 | Select the specified track/layer |
--pp_visible={0,1} | Set whether the property panel is visible |
--infobar_visible={0,1} | Set infobar visibility |
--window_size=1280,720 | Set window size for the Chaos Player application when not maximized |
--http_port=80 | Set HTTP server port |
--brush_size=10 --brush_softness=25 --brush_spacing=5 --brush_color=255,255,255 --brush_opacity=100 | Set brush size, softness, spacing, color, or opacity. |
--global_aspect=1.067 | Set global pixel aspect |
--timeline_visible={0,1} | Set whether the timeline is visible |
--pv_tooltip_enabled={0,1} | Enables/disables the preview area tooltip |
--automatic_preload={0,1} | Enables or disables the automatic preload |
--apply_transforms_to_mask={0,1} | Controls whether pan, zoom and global aspect are applied to the mask |
--stereo_view={left,right,both|stereo} | Displays the left view, the right view, or a stereo view |
--stereo_mode={anaglyph,anaglyph_gm,interlaced, checkerboard} | Sets the stereo mode to anaglyph or interlaced |
--switch_stereo_views={0,1} | Sets the stereo mode to anaglyph, green/magenta anaglyph, interlaced, or checkerboard |
--toggle_ab_wipe | Toggles the A/B wipes on or off |
--enable_ab_horizontal_wipe | Switches the A/B wipe mode to horizontal |
--enable_ab_vertical_wipe | Switches the A/B wipe mode to vertical |
--enable_abcd_wipe | Switches the wipe mode to A/B/C/D |
Layer Properties
--range=1-10,12,13,20-80/2 (first-last/step) | Select a range of frames from a sequence. Must immediately follow the file name. Example: chaosplayer_qt5.exe D:\footage\sequence.####.exr --range=1-200/2 |
--still_image | Add a still image layer instead of autodetecting a sequence. Must immediately follow the file name. Example: chaosplayer_qt5.exe D:\footage\sequence.0001.exr --still_image |
--force_sequence | Add a sequence layer, even if the file doesn't exist or the sequence has a single frame. Must immediately follow the file name. Example: chaosplayer_qt5.exe D:\footage\sequence.####.exr --force_sequence |
--begin=8 | Set layer starting frame on the timeline |
--length=25 | Set layer length in frames |
--in_point=4 | Set layer in point |
--out_point=84 | Set layer out point |
--name=foo | Set layer name |
--position=0,0 | Set layer position |
--alpha={ignore,normal,pm,mask} | Set layer alpha mode |
--blend={normal,add,multiply,screen,difference} | Set layer blend mode |
--depth={ignore,replace,combine} | Set layer depth mode |
--opacity=0..100 | Set layer opacity |
--invert_color=0,1 | Invert layer color |
--invert_alpha=0,1 | Invert layer alpha |
--invert_depth=0,1 | Invert layer depth |
--color_space={default,linear,srgb|sRGB} | Set layer color space |
--lookup_table=filename | Set layer lookup table |
--lookup_table=default, --lookup_table="" | Reset layer lookup table to default |
--exposure=2.4 | Set layer exposure |
--soft_clip=3.1 | Set layer soft clip |
--lift=0.14, --lift_r=-0.01 | Set layer lift; --lift_r, --lift_g, --lift_b are per channel |
--gamma=1.4, --gamma_r=1.8 | Set layer gamma; --gamma_r, --gamma_g, --gamma_b |
--gain=1.2, --gain_r=0.8 | Set layer gain; --gain_r, --gain_g, --gain_b are per channel |
--brightness=-0.1 | Set layer brightness |
--contrast=0.4 | Set layer contrast |
--hue=180 | Set layer hue shift |
--saturation=-8 | Set layer saturation shift |
--disable_cc=0,1 | Disable color corrections |
--auto_update=0,1 | Set layer auto update mode |
--disable_caching=0,1 | Disable caching for this layer |
--pixel_aspect=1.067 | Set layer pixel aspect |
--scale=150 --scale_x=150 --scale_y=150 | Set layer scale |
--flip_x={0,1} --filp_y={0,1} | Flip layer horizontally or vertically |
--border=255,255,255 --border=none | Set layer border |
--border={0,1} | Enable/disable layer border |
--crop=X,Y,W,H --crop=none | Set layer crop rectangle |
--text=0,0,"Lorem ipsum" | Set layer text to "Lorem ipsum". |
--text_align_x={left,center,right} | Set horizontal text alignment. |
--text_align_y={top,center/middle,bottom} | Set vertical text alignment. |
--text_font="Times New Roman" | Set text font to "Times New Roman" |
--text_size=18 | Set text size to 18px. |
--text_bold={0,1} | Set whether the text is bold. |
--text_italic={0,1} | Set whether the text is italic |
--text_color=R,G,B | Set text color |
--text_outline_color=R,G,B; --text_outline_color=none | Set text outline color |
--text_shadow_color=R,G,B; --text_shadow_color=none | Set text shadow color |
--text_back_color=A,R,G,B; --text_back_color=none | Set text background color. A is the alpha and controls the opacity |
--group_id=8 | Set the layer group ID. |
--fade_in=15 --fade_out=15 | Set fade in or fade out portion, in frames |
--primary_key=R,G,B,S,T --primary_key=none --secondary_key=R,G,B,S,T --secondary_key=none | Set primary or secondary color key to (R, G, B), slope S, tolerance T. |
--image_layer="Diffuse" | Set the image layer by name |
--image_layer="" | Reset the image layer to the default |
--image_layer_index=5 | Set the image layer by index |
--target_view={left,right,both} | Set the target view |
--layer_safe_area={0,1} | Enable/disable the per-layer safe area |
--border_color=R,G,B | Set the layer border/safe area color (without enabling the border) |
--layer_channels={r_grayscale,r_color,r_hidden, g_grayscale,g_color,g_hidden, b_grayscale,b_color,b_hidden,rgb,alpha,luma,depth} | Set the layer channnels |
