Command | Description |
--attach | Attach to an already running Chaos Player instance and pass it the rest of the command line. Starts a new instance if no instances are running. Always brings the instance to the foreground. |
--attach_nf | Attach to an already running Chaos Player instance and pass it the rest of the command line. Starts a new instance if no instances are running. Does not bring the instance to the foreground. |
--cmdfile=filename.txt | Execute the commands from filename.txt. |
--transient, --transient={0,1} | Start Chaos Player in transient mode, so that settings are not saved on exit. |
--enable_cpu_render | Starts Chaos Player in CPU mode. Otherwise it runs in the default OpenGL mode. |
