« Previous Version 5 Current »
This section contains details about 2D Textures found in V-Ray for Rhino.
V-Ray for Rhino adds a number of 2D Textures specifically for use with V-Ray. These texture maps provide a variety of patterns useful in different context.
A 2D Texture can be replaced with another 2D Texture or any other type of V-Ray texture via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
