©BBB3viz
« Previous Version 2 Next »
This page provides information on the Raw Sheen Filter Render Element.
The Raw Sheen Reflection Filter Render Element is similar to the Sheer Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection calculated for the VRayMtl Sheen Layer.
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
