This page provides information on V-Ray Physical Camera settings integrated in Solaris Camera LOP node.
Create Camera
V-Ray Camera settings are located in the V-Ray tab of the Camera LOP and they include V-Ray Physical Camera and V-Ray Dome Camera tabs.
V-Ray Physical Camera settings are similar to those under the V-Ray Physical Camera tab, and V-Ray Dome Camera settings are similar to those under the Dome Camera rollout in obj network. The settings become available when you create a Camera LOP from ||stage|| > Cameras > Camera.
UI path: ||stage|| > Cameras > Camera > V-Ray tab
Create and Set Attributes
The parameters that correspond to a USD attribute have a pop-up menu that controls how the LOP node authors the attribute:
Set or Create – Sets the attribute to a given value, regardless of whether the attribute previously existed or not.
Set if Exists – Sets an attribute to the given value only if it previously existed. Use this option to make sure the attribute is set on primitives of the correct type.
Block – Makes the attribute appear to not exist so it takes on its default value.
Do Nothing – Does not affect the attribute, i.e. does not create or change the attribute in any way.
Physical Camera Tab
Main
This tab contains settings for controlling V-Ray Physical Camera basic parameters such as exposure, ISO, shutter speed, white balance, and many others.
Depth of Field
This tab contains settings for controlling depth of field.
Motion Blur
This tab contains settings for controlling motion blur of the V-Ray Physical Camera.
Distortion
This tab contains settings for controlling the distortion sampling for the V-Ray Physical Camera.
Dome Camera Tab
The Dome Camera tab contains settings controlling the V-Ray Dome Camera.
