Square Enix © Goodbye Kansas
« Previous Version 12 Next »
This page gives some basic details about the Refraction Glossiness render element and how it is used in compositing.
The Refraction Glossiness Render Element stores the image's refraction glossiness as a grayscale image that represents the degree of Refraction Glossiness set for materials in the scene. White areas have the most refraction glossiness, while dark areas have little.
The amount of refraction glossiness for a material is set by its Refraction Glossiness parameter. For example, V-Ray Material (VRayMtl) has a Refraction Glossiness parameter, and Skin Material (VRaySkinMtl) has parameters for primary and secondary refraction glossiness.
MultiExcerpt named RE was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Attributes
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.reflGloss.vrimg).
This render element is not supported with V-Ray GPU rendering.
