This page provides information on the V-Ray Standard Render Vars LOP node.
V-Ray Standard Render Vars is a V-Ray specific HDA LOP node that simplifies the render element (AOV) setup. It provides easy access to all commonly used AOVs.
Tabs
Beauty
The Beauty tab provides a basic Back-to-Beauty composite with additional settings for each beauty element for the actual rendering.
Utility
The Utility tab provides common utility elements used in compositing: Shadow, Matte Shadow, Normals, Bump Normals, Velocity, Z-Depth, and Denoiser. Each element has settings for further adjustments.
Sampler
The Sampler tab provides settings for outputs similar to the Ray-Level events for Karma.
Denoiser
The Denoiser tab provides settings for denoising the render.
LPE
The Light Path Expressions tab provides a dynamic menu that generates Light Selects. See the Advanced Light Path Expressions page for more information.
Matte
The Matte tab provides a dynamic menu that generates Cryptomattes.
Cryptomatte
The Cryptomatte tab provides V-Ray Cryptomatte settings similar to those of the V-Ray Cryptomatte Render Element available in the |out| network.
