© Taichi Kobayashi
Now that we've looked at how LPEs work and know the basics, let's look at some advanced concepts and more ways to use LPEs.
Operations
Light path expressions may also include the modifiers placed after event symbols:
? for 0 or one repetition (or an optional event)
+ for 1 or more repetitions (or indirect). See the + modifier example below.
* for 0 or more repetitions (any)
These can be used in combination with the . symbol. It can signify an arbitrary ray spawn event or an arbitrary scattering type, simply put it stands for any symbol.
Symbols in an expression can be grouped.
[] groups event, scatterings and labels
<> groups event, scatterings and labels
[^] inverts events, scatterings and labels
'' labels for masking objects or materials are placed inside single quotations.
| OR (pipe symbol)
() groups symbols.
ExpressionEquivalent (Description)Captured ray paths
C.*LFull light selectcamera (C) → any event (.) that repeats zero or more times (*) → light (L)
CRL
  • simplified for C<R.>L
Direct light select
camera → diffuse reflection → light
camera → glossy reflection → light
camera → singular reflection → light
CR.+LIndirect light selectcamera → any event (.) that repeats one or more times (+) → light
CR?L
camera → light
C<RD>L
  • <> groups events R and D
Lighting (Direct diffuse reflections)
C<R[GS]>L
  • [ ] groups scatters G and S
Specular (Direct glossy and singular reflections)camera → glossy reflection → light
C<RD'1'>L
  • object label 1 is placed in single quotations
Lighting for object label 1camera → diffuse reflection for object with label 1 → light
C<RD[^'1']>L
  • ^ inverts label '1.'Тhis part is placed inside [ ]
Lighting for all objects other than object label 1camera → diffuse reflection for objects that don't have label 1 → light
C<RD>(.+L|.*[OB])
  • .+L means any event, that repeats more than once, until a light hit (L)
  • .*[OB] means any event, zero or more times, until hitting emissive objects (O) or the background (B)
  • | asks for .+L OR .*[OB]
  • [ ] groups O and B
  • ending part is in brackets ( )
GI (Indirect diffuse reflections)camera diffuse reflection any event (.) that repeats one or more times (+) light
camera diffuse reflection any event (.) that repeats zero or more times (*) emission
Previously, we looked at C<T[GS]><RD>L to capture diffuse reflection behind refraction. This will work behind a single refractive pane, as we only ask for a single refractive hit with <T[GS]> that is either Glossy or Singular.
If the refractive object is (for example) a cube, then the ray needs to enter and exit the cube, hitting the refractive surface twice before reaching the diffuse surface behind.
In this case, we need to ask for two refraction hits C<T[GS]><T[GS]><RD>L. If there's no risk of capturing other random refraction hits, we can use <T[GS]>+ to ask for 1 or more repetitions of <T[GS]>
C<T[GS]><T[GS]><RD>L captures the diffuse surface behind exactly 2 panes of refractive surfaces.
C<T[GS]>+<RD>L captures the diffuse surface behind 1 or more refractive hits.
Shadow Mode Prefix
The shadow; prefix in LPE collects and returns shadow information.
It causes the light to accumulate the shadowed contribution out of the light contribution on the last bounce of the ray. It can be used to capture the diffuse or/and specular shadows in the render elements.
Expression
Description
shadow;CDLExtracts shadow from all lights.
shadow;CGL
Extracts shadow from the reflection occlusion of all lights.
shadow;C.'objectLabel'.*L
Extracts shadows that fall over or are reflected in a specific object that is tagged. You can also use it with a material label.
shadow;CD<L.'lightLabel'>
Extracts shadows resulting from a specific labeled light.
shadow;CG<L.'lightLabel'>
Extracts shadows resulting from a specific labeled light in the reflection occlusion.
Capture Objects, Materials and Lights
LPEs can be modified to record information for only specific objects or materials by adding a label, or for only specific lights by adding a tag.
LPE labels for objects
If we take C.* as an example, which gives us the Beauty, C.'1'.* will filter the Beauty only for objects with LPE label 1.
C.'cube'.* will be the Beauty only for objects with LPE label cube.
LPE labels to objects are added in the Object Properties. In Solaris, the LPE labels are added in the Render Geometry Settings LOP > V-Ray > LPE tab. The user attribute name needs to be lpe_label and its value can be text or numbers; for instance: lpe_label=1 or lpe_label=cube.
LPE labels can be anything. You can label an object or material 1, or 2, or testObject, or myMaterial.
When used in expressions, labels need to be placed inside single quotes: C.'cube'.*
Information about Object Properties: Object Properties
Information about Object Properties SOP: V-Ray Object Properties SOP
Information about Render Geometry Settings LOP in Solaris: Working with Solaris Geometry
Adding a Light Path Expression label to geometry
Adding a Light Path Expression label to geometry in Solaris
LPE labels for materials
Similarly, C.'m1'.* can be used to separate the Beauty only for materials with material label 1.
C.'mmyMaterial'.* will be the Beauty only for materials with LPE label myMaterial.
LPE labels are added to materials through the V-Ray MaterialID material, which is added between the material and the output nodes. The label can take numeric or text values and when used in an expression it needs to be preceded by m and placed inside in single quotes.
When used in expressions, material labels require prefixing the label with m and placing the label inside single quotes:  C.'m1' or C.'mmyMaterial'.
Information about adding V-Ray Material ID in V-Ray: V-Ray Material ID Material
Information about V-Ray Material ID in Solaris: Working with Solaris Materials
Adding a Light Path Expression label to materials
Adding a Light Path Expression label to materials in Solaris
Inverting LPE labels
Labels can be easily inverted in expressions by adding ^ in front of them and then placing the inversion symbol and the label inside square brackets [ ].
For example, C.[^'m1'].* will give us the Beauty for all materials that do not have material label 1.
We can invert multiple labels at the same time, for example CR[^'1''2'].+L filters the indirect illumination for all objects that do not have the labels 1 and 2.
LPE tags for lights
C.*<L.'1'> will filter the light contribution of lights with LPE tag 1. It works the same way as a light select.
C.*<L.'topLight'> will be the light contribution from lights with LPE tag topLight.
Another more advanced example is C<RD>.+<L.'1'>, which isolates the GI of a specific light with LPE tag 1.
(C<RD>(.+L|.*[OB]))-(C<RD>.+<L.'1'>) filters the GI of all lights in the scene except for the lights with LPE tag 1.
LPE tags are added to lights through the LPE Tag parameter of the light.
Information about V-Ray lights: Lights
Information about V-Ray lights in Solaris: Working with Solaris Lights
Adding a Light Path Expression tag to lights
Adding a Light Path Expression tag to lights in Solaris
Boolean operations
Boolean operations allow us to combine expressions. We can complement (^), intersect (&) or unite (|) expressions, or we can subtract (-) one expression from another.
Let's look at some examples.
GI can be broken down to different types of light sources: lights, self-illuminating objects, and the environment. If we need to control each of these separately in compositing, we can use the built-in presets, respectively: C<RD>.+L, C<RD>.*O and C<RD>.*B. The combination of these in compositing (with a plus) replaces the GI channel in a back-to-beauty composite. However, if we only need to grade the GI from Lights, we can render a GI render element and C<RD>.+L. Then, we subtract C<RD>.+L from the GI in compositing, grade C<RD>.+L and add it back to the composite.
Alternatively, we can render GI and an LPE for GI minus C<RD>.+L. In this way, we'll only need to add the graded C<RD>.+L channel to the GI in compositing, saving us some compositing complexity.
For the purpose of this example, we can do a union of the GI coming from all three types of light sources to get the GI using the pipe symbol for union: (C<RD>.+L)|(C<RD>.*O)|(C<RD>.*B)
Boolean operations can also be very useful when using LPEs with object or material labels.
Let's look at a simple example with direct lighting. V-Ray already has a render element for this (Lighting) and the equivalent expression is C<RD>L. If we additionally want to capture direct lighting falling onto object(s) labeled cube, we need to render an LPE for C<RD'cube'>L. We can then subtract C<RD'cube'>L from the Lighting channel in compositing, grade it, and add it back in.
Alternatively, we can render the C<RD'cube'>L expression and a second one that does the subtraction right in the renderer: (C<RD>L)-(C<RD'cube'>L). We then grade each channel as needed and add them with a plus in the composite.
