Now that we've looked at how LPEs work and know the basics, let's look at some advanced concepts and more ways to use LPEs.
Light path expressions may also include the modifiers placed after event symbols:
? for 0 or one repetition (or an optional event)
+ for 1 or more repetitions (or indirect). See the + modifier example below.
* for 0 or more repetitions (any)
These can be used in combination with the . symbol. It can signify an arbitrary ray spawn event or an arbitrary scattering type, simply put it stands for any symbol.
Symbols in an expression can be grouped.
[] groups event, scatterings and labels
<> groups event, scatterings and labels
[^] inverts events, scatterings and labels
'' labels for masking objects or materials are placed inside single quotations.
| OR (pipe symbol)
() groups symbols.
Expression | Equivalent (Description) | Captured ray paths |
C.*L | Full light select | camera (C) → any event (.) that repeats zero or more times (*) → light (L) |
CRL
| Direct light select | camera → diffuse reflection → light |
CR.+L | Indirect light select | camera → any event (.) that repeats one or more times (+) → light |
CR?L | ? | camera → diffuse reflection → light |
C<RD>L
| Lighting (Direct diffuse reflections) | camera → diffuse reflection → light |
C<R[GS]>L
| Specular (Direct glossy and singular reflections) | camera → glossy reflection → light camera → singular reflection → light |
C<RD'1'>L
| Lighting for object label 1 | camera → diffuse reflection for object with label 1 → light |
C<RD[^'1']>L
| Lighting for all objects other than object label 1 | camera → diffuse reflection for objects that don't have label 1 → light |
C<RD>(.+L|.*[OB])
| GI (Indirect diffuse reflections) | camera → diffuse reflection → any event (.) that repeats one or more times (+) → light camera → diffuse reflection → any event (.) that repeats zero or more times (*) → emission camera → diffuse reflection → any event (.) that repeats zero or more time |
Previously, we looked at C<T[GS]><RD>L to capture diffuse reflection behind refraction. This will work behind a single refractive pane, as we only ask for a single refractive hit with <T[GS]> that is either Glossy or Singular. If the refractive object is (for example) a cube, then the ray needs to enter and exit the cube, hitting the refractive surface twice before reaching the diffuse surface behind. In this case, we need to ask for two refraction hits C<T[GS]><T[GS]><RD>L. If there's no risk of capturing other random refraction hits, we can use <T[GS]>+ to ask for 1 or more repetitions of <T[GS]> C<T[GS]><T[GS]><RD>L captures the diffuse surface behind exactly 2 panes of refractive surfaces. C<T[GS]>+<RD>L captures the diffuse surface behind 1 or more refractive hits. |
The shadow; prefix in LPE collects and returns shadow information.
It causes the light to accumulate the shadowed contribution out of the light contribution on the last bounce of the ray. It can be used to capture the diffuse or/and specular shadows in the render elements.
Expression | Description |
shadow;CDL | Extracts shadow from all lights. |
shadow;CGL | Extracts shadow from the reflection occlusion of all lights. |
shadow;C.'objectLabel'.*L | Extracts shadows that fall over or are reflected in a specific object that is tagged. You can also use it with a material label. |
shadow;CD<L.'lightLabel'> | Extracts shadows resulting from a specific labeled light. |
shadow;CG<L.'lightLabel'> | Extracts shadows resulting from a specific labeled light in the reflection occlusion. |
LPEs can be modified to record information for only specific objects or materials by adding a label, or for only specific lights by adding a tag.
Labels can be easily inverted in expressions by adding ^ in front of them and then placing the inversion symbol and the label inside square brackets [ ].
For example, C.[^'m1'].* will give us the Beauty for all materials that do not have material label 1.
We can invert multiple labels at the same time, for example CR[^'1''2'].+L filters the indirect illumination for all objects that do not have the labels 1 and 2.
Boolean operations allow us to combine expressions. We can complement (^), intersect (&) or unite (|) expressions, or we can subtract (-) one expression from another.
Let's look at some examples.
GI can be broken down to different types of light sources: lights, self-illuminating objects, and the environment. If we need to control each of these separately in compositing, we can use the built-in presets, respectively: C<RD>.+L, C<RD>.*O and C<RD>.*B. The combination of these in compositing (with a plus) replaces the GI channel in a back-to-beauty composite. However, if we only need to grade the GI from Lights, we can render a GI render element and C<RD>.+L. Then, we subtract C<RD>.+L from the GI in compositing, grade C<RD>.+L and add it back to the composite.
Alternatively, we can render GI and an LPE for GI minus C<RD>.+L. In this way, we'll only need to add the graded C<RD>.+L channel to the GI in compositing, saving us some compositing complexity.
For the purpose of this example, we can do a union of the GI coming from all three types of light sources to get the GI using the pipe symbol for union: (C<RD>.+L)|(C<RD>.*O)|(C<RD>.*B)
Boolean operations can also be very useful when using LPEs with object or material labels.
Let's look at a simple example with direct lighting. V-Ray already has a render element for this (Lighting) and the equivalent expression is C<RD>L. If we additionally want to capture direct lighting falling onto object(s) labeled cube, we need to render an LPE for C<RD'cube'>L. We can then subtract C<RD'cube'>L from the Lighting channel in compositing, grade it, and add it back in.
Alternatively, we can render the C<RD'cube'>L expression and a second one that does the subtraction right in the renderer: (C<RD>L)-(C<RD'cube'>L). We then grade each channel as needed and add them with a plus in the composite.
