« Previous Version 2 Next »
This page guides users who have opted for the Premium Chaos License.
The Premium License can be shared between multiple users and devices. It is recommended for teams. Premium Licenses require one machine to serve as an administrator - this machine holds the license(s) and allows others to join; for more, see the Administrator Workflow. No Chaos product can be used without a License.
Get a Chaos License
Click this button and scroll down to see all Chaos product Licenses.
Corona Activation
If you are activating a Chaos License for Corona, please see the Activating Corona for 3ds Max or Activating Corona for Cinema 4D pages, depending on your integration.
Activating the License
If you are connecting to a Premium License, which is not located on your machine, you are using a Remote Licensing setup. The remote license server is typically managed by your IT administrator and activated with your company Chaos account that holds your Premium licenses.
  • Ask your license administrator for the License Server's IP address.
  • Download your Chaos product(s) and run the installation wizard. After accepting the End User License Agreement, you need to select the Advanced installation option.
Example screenshot
  • At the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port.
  • Continue to finish the installation. As long as your license administrator's license is active, you can use the remotely shared license.
Example screenshot
