This page provides information on how to uninstall Corona.
The installer automatically updates Corona to the newer version if it detects an older version. If you need to manually uninstall Corona, please make sure that 3ds Max or Corona components, such as the Corona Image Editor, are not being used. For silent uninstallation, see: How to perform silent installation and uninstallation at the Chaos Help Center.
Uninstalling Corona
The Uninstaller originally resides in the following location - C:\Program Files\Corona\Corona Renderer for 3ds Max\Uninstaller
Running RemoveCoronaForMax.exe starts the Corona uninstaller. Click OK to proceed with the uninstallation or Cancel to quit the uninstaller.
You can also use the Windows "Add or remove programs" utility to uninstall Corona.
Leftover Files
After the uninstallation is complete, there may be some leftover files that you need to delete manually. Please check if the following folders are present and delete them:
- %programfiles%\Corona
- %localappdata%\Autodesk\3dsMax\20xx - 64bit\ENU\en-US\plugcfg\corona
- %programfiles%\Autodesk\3ds Max 2024\Plugins\ (Delete only corona-related files from here if present)
