Version 1 Current »
This page provides information about the Toon Lighting Render Channel in V-Ray for Blender.
The Toon Lighting Render Channel stores direct lighting information from lights in the scene that hit the Toon Material. This render element can be used to brighten, lessen, or tint the direct lighting in a composite without affecting indirect light or reflections, for example.
The Toon Lighting Render Channel is included in the Lighting Render Channel. It can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Toon Lighting
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping  Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
