This page contains information about the individual file Settings.
UI Path
Open the File Settings menu by following:
||Virtual Tour Tool Ribbon|| > Edit > Current file > Settings
Title and Description
Title – Displays the name of the currently selected file.
Description –  Displays a description of the file.
Panorama Settings
Panorama mode – When enabled, panorama images are displayed in panorama view. When switched off, the panorama image appears flat. Equirectangular/spherical panoramas, cube and stereo panoramas (left-right & top-down types) are supported in this mode.
Automatic – Calculates the orientation automatically to simulate movement in the correct direction based on the existing hotspots. (default)
Original – Preserves the original default orientation as the image is rendered.
Custom – Allows setting a custom starting orientation for panoramas.
Additional Settings
Premultiplied alpha – Marks the uploaded image as an image with premultiplied alpha and visualizes it as such.
