« Previous Version 12 Current »
This page provides information about the V-Ray Atmospheric Effects render element in Cinema 4D.
The Atmosphere Render Element stores only atmospheric or volumetric participating media such as Environment Fog or Aerial Perspective. This render element can then be used to enhance or color-correct just the atmospheric component of the image during the compositing process.
When atmospheric effects or fog are included in a scene, they render into the Beauty|RGB channel and should also be output as the VRayAtmosphere channel for compositing use.
UI Path: ||V-Ray|| > Render Elements > Atmospheric Effects
How to add a render element to a scene
beauty render Before image
atmospheric effects After image
Properties
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color MappingApplies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Example: Enhancing Atmospheric Effects
In this example, the fog density in the scene is increased after rendering using the Atmospheric Effects Render Element. A Color Balance layer is also applied to the Atmospheric Effects to adjust the color of the fog.
before Before image
after After image
