This page provides information on the Resimulation rollout for a LiquidSim object.
Liquid Resimulation uses an already simulated cache sequence and allows you to add, delete or modify the Splash, Mist, Foam or Wetmap particle systems. It will preserve the Liquid and the particle systems you are happy with.
The particle resimulation will affect only the particle systems which are checked in this rollout. If a particle system is not checked, it will remain unchanged. The Liquid always remains unchanged. While the Fire/Smoke Resimulation creates new cache files during the simulation process, the Liquid Resimulation overwrites the existing cache files.
Using Resimulation to just modify a particle system is practical only in case you have a large number of secondary particles such as Foam, Splash, etc in relation to the number of Liquid particles. If you have mostly Liquid particles and very few other particles, it will be faster to just simulate again.
The Affect Liquid parameter on the Splash and Mist rollout will be ignored when resimulating Splash, because the liquid is already simulated and cannot be changed without a full simulation.
You can resimulate over the resimulated caches and so on - it's not necessarily just 2 passes at most.
UI Path: ||Select Liquid Simulator | LiquidSim object|| > Modify panel > Resimulation rollout
Enable Particle Resimulation | resim_resimulate_particles – Enables the resimulation.
Splash and mist | resim _splash – Specifies that the splash and mist will be recalculated.
The Affect Liquid parameter on the Splash and Mist roll-out will be ignored when resimulating Splash, because the liquid is already simulated and cannot be changed without a full simulation.
Foam | resim _foam – Specifies that the foam will be recalculated.
Wetting | resim _wet – Specifies that a WetMap will be recalculated.
The Sticky Effect setting for Wetting in the Liquid rollout will be ignored when resimulating wetting. This is because the liquid is already simulated and cannot be changed without a full simulation.
? – Opens up the help documents for the Liquid Resimulation process.
