This page gives information on the Wire Color Render Element.
The Wire Color Render Element stores the wireframe color of the object as set in the 3ds Max scene. The color is flat, with no highlights or shadows. This render element can be used to generate masks for objects for use in compositing.
Use VRayWireColor when you wish to separate objects by wireframe color rather than by Object ID or Material ID.
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Common Uses
The Wire Color Render Element is commonly used to create a mask for objects in a scene for color correction or color grading. In the example below, a matte was created for the floor and then used to change the color of the floor by using color correction in composite.
Matte generated from purple wire color
of the Wire Color Render Element
Original Beauty composite
Color correction of floor using matte
