This page provides information about the Bezier Curve Correction texture in V-Ray for Rhino.
The Bezier Color Correction texture is one of the three available Color Correction textures along with Color Correction and Spline Color Correction. The Bezier Curve texture allows remapping any other texture color values using RGB or Luminance curve controls.
To color-correct a specific texture using a Bezier curve, simply right-click on the texture slot to bring up its context menu select Wrap In and choose Bezier Curve. This will place the existing texture within a Bezier Curve and then plug it in the original slot.
UI Paths
||V-Ray Asset Editor|| > Textures (right-click) > Bezier Curve
||V-Ray Asset Editor|| > Create Asset (left-click) > Textures Bezier Curve
Input – Specifies a color or texture to be bezier corrected. When a texture is selected, it overrides the color as long as the texture checkbox is enabled.
Mode – Changes the set of beziers used for color remapping. You can select between Mono or RGB mode.
RGB – Red, Green, and Blue curves are used for remapping the separate image channels.
Mono – The texture luminance is remapped based on a single curve.
Tangent Type – The handles type of the selected curve control point.
None – No handles.
Free – The Bezier handles are unlocked.
Locked – The handles' angle and length are locked.
Position – The position of the selected curve control point. The position cannot surpass neighboring points or their tangent handle positions.
Value – The value of the selected curve control point.
