« Previous Version 2 Next »
This section contains details about General Purpose Textures found in V-Ray for Rhino.
The General Purpose Textures offer optimized common input for materials and allow for further integration with other V-Ray package tools. The General Purpose maps allow users to create solid colors or temperature maps for use with materials as well as use HDRI maps in their scene.
A General Purpose Texture can be replaced with another General Purpose Texture or any other type of V-Ray texture via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
The Bitmap texture settings are organized in Basic and Advanced modes. You can switch the mode from the toggle button () under the Preview Swatch or globally from the Configuration rollout of the Settings tab.
