This page provides information on the V-Ray Infinite Plane.
The VRayPlane is a very simple plugin that implements a procedural infinite plane primitive for V-Ray. The source code of VRayPlane is also available as part of the V-Ray Geometry SDK.
The VRayPlane can be created from the the VRay category of the Create panel.
The 3ds Max teapot sitting atop a VRayPlane.
This plugin has a single parameter which allows the user to enable and disable the display of the VRayPlane in the view port.
- The position of the plane depends on its transformation in the 3ds Max scene.
- You can have more than one infinite plane in the scene.
- The plane is rendered with the material applied to the VRayPlane object.
- Shadow maps will not include information about the plane object. However, other objects will cast correct shadows on the plane, even with shadow maps.
