This page provides information about the Export and send as .vrscene to Chaos Vantage MAX script.
The Export and send the current scene as static .vrscene to Chaos Vantage and Export and send the current animation range as a .vrscene to Chaos Vantage MAX scripts help you to send your 3Ds Max scene and animations to Chaos Vantage with a click of a button.
Installation
The installation of the tools comes as an option with the Chaos Vantage standard installation.
From the Installation window, choose the Advanced option.
Enable the Install V-Ray for 3ds Max Live Link option. It automatically installs the Initiate Live Link to Chaos Vantage option, Export and send the current scene as static .vrscene to Chaos Vantage, Export and send the current animation range as a .vrscene to Chaos Vantage , as well as the Import Changes from Chaos Vantage tools compatible with 3ds Max versions 2019, 2020 and 2021.
V-Ray for 3Ds Max Live Link script option will only be available if V-Ray 5 for 3ds Max, update 1 and later is installed.
UI Path
To access the script, go to ||Customize|| > Customize User Interface > Toolbars > Export and send the current scene as static .vrscene to Chaos Vantage
For convenience you can drag-n-drop it in any toolbar for faster access.
To access the script, go to ||Customize|| > Customize User Interface > Toolbars > Export and send the current animation range as a .vrscene to Chaos Vantage
Usage
To use the script just click on the Export and send the current scene as static .vrscene to Chaos Vantage or Export and send the current animation range as a .vrscene to Chaos Vantage button. The script will automatically:
- Detect if you are using V-Ray 5 GPU as a renderer and ask if you would like to switch to it.
- Stop IPR or Live Link session.
- Start Chaos Vantage if it is not already running.
- Еxport the scene in a .vrscene file in the .max project location with the name of the .max file.
- Open the scene in Chaos Vantage.
