This page provides information about the real-time viewer V-Ray Vision.
V-Ray Vision is a real-time viewer that can be used in any project set up for V-Ray rendering. It is a lightweight “game engine” (rasterizer) that does not currently use any type of ray-tracing. Due to its speed, it can serve as a powerful alternative viewport that provides better lighting and material representation as well as camera animation playback controls.
In addition to its main function as a viewer, V-Ray Vision can produce spherical panoramas and quick output of both still frames and animation sequences. It comes with its very own auto-exposure, tonemapping, and color correction options.
When V-Ray Vision is launched, it automatically loads the current SketchUp project and starts an interactive session. This means that while it is running, a live link is established that sends to the viewer all updates made to the SketchUp scene.
Stopping the live link, by either clicking the SketchUp toolbar's V-Ray Vision button or any of V-Ray's Render buttons, ends the connection but does not clear the loaded scene. To stop V-Ray Vision, close its window.
In addition to loading scenes directly from SketchUp, V-Ray Vision is able to load .vrscene files directly. In this case, in order for the modifications to be displayed, the source file has to be reloaded.
V-Ray Vision Menu
Indicates whether the live link with V-Ray is currently active. Click on the button to open the Live link parameters panel: Sync Camera – Sync vision camera with the host application viewport. | |
| Selects a .vrscene file to be loaded in the viewer. |
Shows or hides the information panel and the shortcuts. | |
Resolution mode. Click on the button to cycle between the following modes: Fit in Window – Matches the window size and aspect. | |
Camera Navigation Mode. Click on the button to cycle between the following modes: Orbit mode – enables the camera movement based on orbit, pan, and zoom manipulations. | |
Enables/disables Auto Exposure.1 | |
Opens the Settings panel. | |
Opens the Color Corrections panel. | |
Opens the Save Options panel. |
Enable Proxy LOD – Enables the LOD switching for Proxy Mesh assets. The full mesh is visible up close, whereas the proxy preview mesh is displayed in distance. Note that both share materials.
High quality cosmos assets – Shows high quality Cosmos asset version when the object is close to the camera. Cosmos assets have multiple levels of detail and by default Vision loads lighter meshes for increased performance. Note that enabling this option can impact performance and loading time depending on the assets used. Restarted Vision for this setting to take effect.
Shadows Quality – Controls the quality of Sun, Directional, Omni and Spot lights. From the drop-down you can choose from:
Low – Low quality shadow map filtering is used. Shadow map size is decreased during scene interactions.
Medium – Medium quality shadow map filtering is used. Soft shadows are disabled.
High – High quality shadow map filtering is used. Soft shadows are supported. Changing the Sun size affects the shadow softness.
Temporal Anti-aliasing – Enables a higher quality anti-aliasing method. Note that this is a compute expensive option and needs multiple frames to achieve good-looking results.
Auto Exposure1 – Enables auto exposure. Note that when enabled, if there are sizeable very dark or light portions of the buffer (e.g. completely black background surrounding a model), they may produce an exaggerated exposure value adjustment.
EV Compensation – Multiplies the exposure value of the camera or the value calculated by the Auto Exposure (when active). This option can store two independent values based on whether Auto Exposure is active.
Fly Mode – Changes the view navigation mode. Use the W, A, S, D, Q, E keys on the keyboard to move around. Holding down Space temporarily increases the movement speed. Hold the Left Mouse Button to look around
Fly Speed (m/s) – The movement speed measured in meters per second. Only has an effect in Fly mode.
Mouse Sensitivity – Changes the mouse speed when looking around in Fly Mode.
Smooth Movement Delay – The time it takes the camera to gradually cease after being moved during Fly Mode. Calculated in seconds.
Automatic IBL Sun – Automatically adds a directional light based on the brightest spot in an HDR image. The option has no effect if the project Sun is enabled. It is not recommended to enable it if there is no single distinct bright spot in the image used for lighting.
Color Corrections
Tonemapping Curve – Specifies the type of tonemapping applied to the image.
Disabled
ACES Curve
Exposure – Controls the post-exposure value.
Contrast – Controls the post-contrast amount ranging from -100 to 100.
Saturation – Controls the post-contrast amount ranging from -100 to 100.
Temperature – Controls the post color temperature value ranging from -100 to 100.
Tint – Controls the post color tint value ranging from -100 to 100.
Reset – Resets all color corrections values to 0.
Load – Loads color corrections preset file.
Save – Saves the color corrections as a .visioncc file that can be loaded later.
Save Options
File – Specifies the output image file path.
Image Format – Specifies the output image file type between .png, .jpg, .tga or .exr.
Camera Type – Saves the output image file as one of the following camera types:
Standard – Uses a standard pinhole camera.
VR Spherical Panorama – Uses a spherical panorama to save the image.
VR Cubemap 6x1 – A cubic/box camera with the cube side arranged in a single row.
VR Cubemap 6 images – A cubic/box camera with the cube sides saved as separate images.
Note that the view direction is ignored. The VR cameras always use a default orientation. Screen-space reflections are disabled in these modes to avoid artifacts.
Resolution Mode
From Vision Window – The window size determines the output image size.
From Project – The image size specified in the host application or the V-Ray scene determines the output image size.
Output Resolution – The final output image resolution. Note that the size multiplier value is also taken into account.
Size Multiplier – Multiplier for the base resolution. Note that there is a hard limit of 8192 pixels for the long edge of the image to avoid video memory issues.
Super Sampling – Reduces aliasing. Larger values are slower to render and require more video memory available. Note that there is a hard limit of 8192 pixels for the long edge of the image to avoid video memory issues. No supersampling is performed if the long edge of the image is already set to 8192 pixels.
Export Animation – Enables animated sequence export.
Animation FPS – Controls the number of frames per second when exporting sequences.
Export – Exports a still image if the Export Animation is disabled. Exports an image sequence if the Export Animation is enabled.
Shortcuts
These shortcuts navigate through V-Ray Vision.
Shortcut | Description |
Ctrl + Space or Ctrl + O | Opens a .vrscene file. |
Ctrl + Backspace or Ctrl + N | Clears the scene. |
Tab | Changes the camera navigation mode. |
Left-click | In Orbit mode, it allows to orbit. In Fly mode, it allows looking around. |
Right-click or Scroll | In Orbit mode, it allows zooming. In Fly mode, it allows looking around. |
Middle-click | In Orbit mode, it moves the camera left and right. In Fly mode, it allows looking around. |
W, A, S, D | In Fly mode, allow for moving around. |
Q, E | In Fly mode, allow for moving up or down. |
Space | In Fly mode, it temporarily increases the movement speed. |
C | Resets the camera. |
Shift + Left-click | Moves the Sun. Up/Down – Altitude |
Shift + Right-click | Up/Down – Changes the sun intensity. |
Shift + Middle-click | Up/Down – Changes the camera exposure. |
F5 | Resets the sun position and the lighting changes so to match the original scene state. |
Footnotes
1- Note that when Auto Exposure is enabled, sizeable very dark or light portions of the buffer (e.g. completely black background surrounding a model), might produce an exaggerated exposure value adjustment.
- V-Ray Vision is part of V-Ray for SketchUp and does not require additional licensing.
- V-Ray Vision requires hardware capable of running DirectX 11 or DirectX 12 and Shader Model 5.0
- Scenes with Chaos Cosmos assets can be rendered in V-Ray Vision.
- Temporal Anti-aliasing is disabled when spherical panorama images are exported.
