Installing V-Ray
Setting up V-Ray for SketchUp comprises of downloading and installing V-Ray for SketchUp, and downloading and activating the License Server. Note that if you use SketchUp version prior to 2019, the V-Ray plugin must be enabled from the render package.
System Requirements
Check if your hardware matches the minimum requirements to run V-Ray: System Requirements
Install V-Ray
If you are an edu/commercial user, check how to download and install V-Ray for SketchUp: Installation
Try V-Ray
If you are a trial user, check how to download and install V-Ray for SketchUp: Free Trial
Silent Installation
Complete V-Ray installation without user input during the process, using a predefined set of options: Silent Installation
Swarm Installation
V-Ray Swarm allows you to split your rendering across multiple computers: Swarm Installation
Licensing
See how to install and activate the License Server: Licensing
Data Collection
Find out how you can help V-Ray become better: Chaos Group Telemetry
End User License Agreement
Read the full legal agreement between Chaos Group and the end-user: License Agreements and Copyrights
