This page provides information about the Materials tab in Chaos Vantage.
The materials tab offers a list of all materials in the scene. This includes materials imported with .vrscene file.
Button | Description |
Assigns a material from the list to the selected objects in the scene. Available only when a material is selected. | |
Selects all scene objects based on the material that has been selected in the list. Available only when a material is selected. | |
Selects the material of the selected object in the scene. Available only when an object is selected. | |
Opens the Preview scene settings dialog. | |
Filters the material list and shows only the ones that contain the input string | |
Clears the filter string. | |
Filter menu that enables the listing of materials based on type e.g. Generic, 2 Sided, Multi material, etc. | |
| Controls the amount of columns in the materials list: |
Sorts the material list: |
There is also a context menu with a right click on a material thumbnail:
Select objects by material – Selects all scene objects based on the material that has been selected in the list. ()
Assign material to selection – Assigns a material from the list to the selected objects in the scene.()
Assign material to selection and its children – Assigns a material from the list to the selected objects and their children in the hierarchy in the scene.
Delete unused Cosmos material assets – Deletes any currently unused imported Cosmos material assets. This will free up GPU memory.
Materials can also be assigned to objects by drag-and-drop. There are also modifier key combinations with drag-and-drop with the following functionality:
- Alt+drag-and-drop replaces material on all object with same material
- Ctrl+drag-and-drop assigns material to objects and its children
Preview Scene Settings
The Preview scene settings dialog contain options to customize how the material thumbnails are rendered.
Load vrscene – Loads a custom vrscene file for the material preview scene.
Samples – Specifies the samples per pixel for refining the material thumbnail. Low values will speed up thumbnail generation at the cost of quality.
Preview mesh – Specifies the mesh that will be used in the material thumbnail:
Sphere
Cube
Cylinder
Shaderballl
Liquid
Cloth
Preview camera – Specifies the render camera for the material thumbnails:
Main
Zoom
Environment mode – Specifies the mode which will be used for scene lighting.
Texture – Enables the use of an environment texture for lighting. When this option is selected, Load environment and Rotation parameters appear.
Solid Color – Enables the use of a solid color for lighting. When this option is selected, Environment Color parameter appears.
Load environment – Loads an image for Environment. This option is available only when Environment mode is set to Texture.
Flip horizontally – Flips the environment image horizontally. This option is available only when Environment mode is set to Texture.
Rotation – Specifies a rotation angle in degrees for the Environment texture. This option is available only when Environment mode is set to Texture.
Intensity – Specifies the intensity of the Environment lighting.
Rim Light – Enables/disables and controls the intensity and color of the rim light in the default preview scene.
Fill Light – Enables/disables and controls the intensity and color of the fill light in the default preview scene.
Front Light – Enables/disables and controls the intensity and color of the front light in the default preview scene.
Internal Lights – Enables/disables and controls the intensity and color of the internal light in the default preview scene. Useful for previewing two sided materials.
Close – Closes the Preview scene settings dialog.
