©BBB3viz
« Previous Version 7 Next »
This page gives some basic details about the Raw Refraction Render Element and how it is used in compositing.
The Raw Refraction Render Element is a color image that stores refraction information calculated from materials' refraction values in the scene. Surfaces with no refraction values set in their materials contain no information in the render element, and therefore render black.
In comparison, the Refraction Filter Render Element (VRayRefractionFilter) is a render element that indicates varying degrees of refraction in the scene, through brightness values in the image. Multiplying these two render elements together produces the VRayRefraction Render Element (VRayRefraction).
Note: To properly calculate the Raw Refraction Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
Common Uses
The Raw Refraction Render Element is useful for changing the appearance of refractive elements after rendering in a compositing or image editing application. Below are examples of possible uses.
Original Beauty Composite
Brightened Refractions
Tinted Refractions
Underlying Compositing Equation
VRayRawRefraction x VrayRefractionFilter = VRayRefraction
  • To properly calculate the refraction information in the Raw Refraction, Refraction Filter and Raw Refraction Filter Render Elements, the Refraction Render Element must also be rendered at the same time, even if it's not going to be used in the compositing process. Doing so enables all the refraction information to be included in the rendering calculations.
