©BBB3viz
« Previous Version 2 Next »
This page provides information on the Sheen Glossiness Render Element.
The Sheen Glossiness Render Element is analogous to the Mtl Reflect Glossiness Render Element. This channel holds a float number with the value set in the Sheen Glossiness parameter in the VRayMtl Sheen Layer.
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
