Square Enix © Goodbye Kansas
Version 1 Next »
Beta release
Date - , 2022
Release notes: V-Ray 6, Beta
Try V-Ray 6 for Maya, beta
V-Ray Sun Clouds
Craft just the right cloudy sky for your environment in just a few clicks with V-Ray’s new procedural clouds system.
For more information, see the VRaySun page.
Thin Film Layer
Create realistic soap bubbles, oil spills, and more with the new Thin Film option in the V-Ray Material.
See the VRayMtl 's page.
New ground projection
Elevate your HDRI environment renders with the new, more flexible ground projection capabilities of the V-Ray Dome Light.
Infinite
Finite
Enhanced V-Ray Material energy preservation
Render even more physically accurate rough metals and other reflective surfaces with enhanced V-Ray Material energy preservation.
See the VRayMtl's page.
V-Ray Decal with Displacement
You can now use V-Ray Decal to add displacement to any surface for even more realistic cracked walls, rocks, embossed lettering, and more.
Streamlined USD Support
VRayMtl can be exported as a USDPreviewSurface, so that V-Ray assets can be displayed in various non-V-Ray viewports. Find out more at USD.
 V-Ray Material Faster Translucency
Render translucent materials even faster with a brand-new V-Ray Material SSS mode
Light Cache in IPR
IPR can now use the Light Cache GI, making IPR and production renders identical.
VFB Panorama Viewer
Now you can preview your spherical panorama renders while rendering, right from your V-Ray Frame Buffer.
Composition Guides Layer in VFB
Fine-tune your scenes’ compositions without going to a separate application. With customizable overlays, the new composition guides layer in the VFB allows you to easily experiment and enhance your image compositions.
Non-blocking Submit to Chaos Cloud
Submitting to the Chaos Cloud now happens in a separate process, which leaves the Maya interface free so that users can continue working.
