©BBB3viz
« Previous Version 13 Current »
This page provides information on the V-Ray Infinite Plane.
The VRayPlane implements a procedural infinite plane for V-Ray during rendertime. The source code of VRayPlane is also available as part of the V-Ray Geometry SDK.
It can be created from the the VRay category of the Create tab.
||V-Ray Toolbar|| > V-Ray Plane button
||V-Ray menu|| > Create > Geometry > V-Ray Plane
||Create menu|| > V-Ray > V-Ray Plane
||Command panel|| > Create tab > Geometry > V-Ray category > VRayPlane button
The 3ds Max teapot sitting atop a VRayPlane.
This plugin has a single parameter which allows the user to enable or disable the display of the "VRayPlane" text in the viewport.
  • The position of the plane depends on its transformation in the 3ds Max scene.
  • You can have more than one infinite plane in the scene.
  • The plane is rendered with the material applied to the VRayPlane object.
  • Shadow maps do not include information about the plane object. However, other objects cast correct shadows on the plane, even with shadow maps.
