©BBB3viz
« Previous Version 11 Current »
This page gives information about the Total Lighting Render Element.
The Total Lighting Render Element is a color image that includes the effects of both direct and indirect lighting on materials in the scene, including the diffuse component. It is a result of adding the VRayLighting and VRayGlobalIllumination render elements, or of multiplying the VRayRawTotalLighting and VRayDiffuseFilter render elements.
VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Since V-Ray 6 only exposure color mapping is applied to the VRayTotalLighting render element.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Common Uses
The Total Lighting Render Element is useful for brightening or dimming all lighting during compositing. Below are a couple of examples of its use.
Original Beauty Composite
Brightened Lights
Tinted Lights
Compositing Formulas
VRayRawTotalLighting x VRayDiffuseFilter = VRayTotalLighting
VRayLighting + VRayGlobalIllumination = VRayTotalLighting
