Version 1 Next »
This is article explains how to the use the Corona Benchmark.
What is the Corona 10 Benchmark?
The Corona Benchmark is an application based on the Corona 10 rendering core which measures your system performance by rendering a scene with Corona 10 without having to run (or even install) any other software. It can be used to measure how well your system performs when rendering with Corona and you can compare your score with other users' results to make sure your hardware is running as at its full capacity or just for fun!
Some other uses include:
  • Comparing what improvements (if any) result from changing something about your hardware, BIOS settings, or Operating System settings
  • Making an informed decision on what hardware to buy by making sure it gives you a notable performance improvement
  • Stress testing the machine to make sure that the cooling can keep up with your CPU when it is hard at work (via command console)
Where to find the Corona 10 Benchmark?
