This page provides information about the VRmat material in V-Ray for Cinema 4D.
The VRmat material is useful for working across multiple platforms; the VRmat loads a V-Ray shader from a file (.vrmat, .vismat, .vrscene, .mtlx) and makes the materials in these files available for use in the scene. These files can be exported from Maya or 3ds Max and used on any platform.
To share materials cross-platform, an existing V-Ray material is converted through the VRMat Converter, the output of which can then be read into a scene using the VRmat material in the material editor of the destination platform. This allows you to use a material originally created in 3ds Max or Maya in a Cinema 4D scene.
Note: If you load a shader from a .vrscene file, you can only use it directly; you cannot edit it.
If you want to edit the scale of the VRmat's UVs, you can do so using the VRayObjectProperties tag, which adds additional UV scaling. See the VRayObjectProperties page for more information.
22_VRayVRmatMtl
UI Paths
||V-Ray|| > VRmat Material
||Create|| > V-Ray > VRmat Material (disabled Separate menu for V-Ray materials)
Material File – Loads a .vrmat, .vrscene, or .vismat containing one or more V-Ray materials or a .mtlx file.
Material Name – A list of all V-Ray materials saved inside the loaded .vrmat, .vismat, or .vrscene file or material loaded inside the .mtlx file.
c4d2024_62010_VRayVRmat_material_params
Options
Material Id Enabled – Enables the use of Material ID.
Material ID – The color used by the Material ID render element. You can also use a shader here.
Multimatte ID – The integer ID of the material to be used by the Multi Matte render element.
Round Edges Enabled – Enables the Round Edges effect, which uses bump mapping to smooth out the edges of the geometry during render time.
Radius – Specify a radius (in world units) for the Round Edges effect. Since the actual geometry is not being changed and only the normals of the faces are affected, large values may produce undesirable effects.
Consider Same Object Only – When enabled, the rounded corners are produced only along edges that belong to the object, which has the attribute applied. When disabled, rounded corners are also produced along edges formed when the object with the attribute intersects other objects in the scene.
Corners – Choose which edges are considered in the calculation. Possible options are:
Convex and Concave – Considers all edges.
Convex Only – Only applies Round Edges effect to edges with convex angles.
Concave Only – Only applies Round Edges effect to edges with concave angles.
Preview Settings
Override Preferences – When enabled, the parameters in this tab override the global preferences of the scene for the selected material.
Enable Preview – When disabled, the previews of the material in the Viewport and the Material Editor are disabled. The material is displayed in all black. This saves on processing power.
Enable Global Illumination – When disabled, global illumination is not calculated for the current material preview.
Quality – Determines the quality of the material previews. Higher values give more detail but slow down processing.
Editor Map Size – Determines the resolution of the material preview. If you have extra-detailed textures applied to the material, this option allows you to preview those textures in higher resolution at the preview step, without needing to render.
Default
64×64 (16 KB)
128x128 (64 KB)
256x256 (256 KB)
512x512 (1 MB)
1024x1024 (4 MB)
2048x2048 (16 MB)
4096x4096 (64 MB)
