Once the location has been determined, the area and position of the model needs to be determined. By default, an area of 1000 x 1000 meters is set. To determine the site area, the following options are available: Resize – Simply drag one of the sides of the orange bounding box that defines the area intended to be imported. The size will be indicated in meters. Rotation – Hover the mouse cursor near a corner, until it changes, at which point you can click on the corner and rotate the area by moving your mouse Translate – Move the pin to the desired location, and click on Fit to Location Once the site model has been imported, its position can be updated later. The orange pin icon in the map indicates where your CAD project model will be placed in the site context model to be imported. The location of the CAD model can be translated / rotated by dragging the pin / hovering on the circular arrow symbol (you may have to zoom in on the map to be able to see this symbol) respectively. When you hover over this circular arrow to rotate the CAD model, the mouse cursor will change accordingly. Click and hold on the circular arrow symbol, and drag the mouse up/down to rotate the CAD project, releasing the mouse button when you’re happy with the adjustment. In the lower left corner of the map viewport you will find four buttons: Zoom tools (+, –) – Allows you to zoom in and out (or simply use the mouse wheel) Go to Location – Centers the map on the pin location Fit to Location – Centers the area selection around the pin and sets its dimensions to 1 Km x 1 Km. The model rotation is also reset. |
