This page provides information on the Licensing Server Controller.
The License Server Controller allows users to make adjustments to the Chaos License Server through the command line.
Depending on your operating system, the vrlctl command's default location is as follows:
Windows | C:\Program Files\Chaos\VRLService |
Linux | /usr/Chaos/VRLService |
macOS | /Applications/Chaos/VRLService |
To use the License Server Controller, use the following format:
vrlctl <command> |
When entered without a command, additional help information will be displayed.
Adding the help flag --help or -h after each command prints additional information about the command:
vrlctl online enable -h |
The following commands are available:
These commands provide a way to enable, disable, and monitor online licensing settings of the license server. For steps on setting up online licensing, see the Borrowing Offline Licenses section below.
online getcsr | Saves an online licensing request file (cert.csr) in the current directory. |
online enable | Enables online licensing using an online licensing key file (cert.crt) from the current directory. |
online logout | Disables online licensing for the license server. |
online status | Displays information about the online licensing status. |
online login <username> <password> | Activates online licensing for the specified credentials. |
These commands help you obtain the diagnostic bundle which can assist ChaosGroup's support team when investigating problems you might encounter.
diagnostics get <save_path> | Downloads the diagnostic bundle. If <save_path> is provided, the diagnostic bundle will be saved in the given directory. |
These commands allow users to get or set different configuration variables of the Licensing Server.
config get | Returns the complete license server configuration. |
config set <configuration_option> "<new_value>" | Sets the value of a specific configuration option. The configuration option consists of all the configuration nodes that lead to it connected with a dot ( |
These commands are for using a dongle with the License Server. See the Dongle usage page for additional information.
dongle enable | Enables the dongle server. |
dongle disable | Disables the dongle server. |
The browser command opens the License Server's web interface page in your system's default browser. See the Viewing Your Available Licenses page for more information.
vrlctl browser |
Adding the help option after a command prints additional information about a specific command.
The version option prints the version of the Licensing Server Controller.
vrlctl -v |
Follow these steps to borrow a license server for offline use through the License Server Controller. Keep in mind that you need an Internet connection to borrow a license, but once you have successfully activated it, you can work offline for up to 14 days. The activation can be renewed every time. For more information, see the Borrowing Licenses for Offline Use page.
Note for Offline License Holders Please note that the online steps (2 and 3) in this section can be performed by a separate device with an Internet connection. The downloaded cert.crt file can be transferred to the offline license holder, allowing you to borrow licenses even when your license holder does not have an Internet connection. |
