This page provides a tutorial for manually creating a heavy smoke effect for a fire simulation.
Start with a fire simulation such as the Simple Fire Simulation.
Select the PhoenixFDSource and decrease the Temperature below 300 Kelvin. This will make the emitted fluid heavier than the empty cells and cause it to sink.
Increase the amount of Smoke that will be emitted.
Select the PhoenixFDSimulator. In the Dynamics rollout, make sure that Uniform Density parameter is disabled.
In the Output rollout, make sure the Smoke parameter is enabled.
If the emissive component is not needed for rendering, uncheck the Temperature in the same section.
Start the simulation.
